Foglights wont work
    Foglights wont work
    i have a 93 Cb7 wit the oem fogs. for some odd reason they wont turn on anymore. i switched the bulbs to see if they would work and nothin. i have a strong feelin that its the main relay for the fogs. i need to know were exatly it is because its driving me crazy not havin them turned on. thanks
    Have you checked the fuse. I think the relay is attached on the radiator support (I Think).
    1993 Accord EX
    2011 Subaru STi
      You can go to your local dealer parts and buy them a new relay for the fog lights and they should give you a printout or copy of their repair manual to see where it goes. My signal light switch broke a couple days ago along with signal light switch and that's what I did.
        o aaight thank you
          the relay is under your dash somewhere if they used the factory harness and stuff. look above the pedal area near the cruise control box and fuse area.
          the only thing out in the engine bay should be a ground wire and the fogs themselves.
            That's where I was going to suggest. Under the dash. The 9091's hook to a bolt on the cruise control module. Have you tried the ground wire? that was the issue with mine, the ground somehow became bad? they wouldn't work. But, they're working now
              Man im having the same exact problem!! i changed the bulbs,relay and even the ground thats located in the engine bay!! and still Fog light no worky!! its driving me NUTS....dont know what else to do?
                Bump 4 Sum help!!
