cam gears, pulleys, etc
    was wandering if i should change my cam gears, pulleys, etc. the question is if i change these should i change camshaft( or crankshaft)
    I'm not trying to be a smartass be could you be more specific??? You could change them to get rid of some parasitic loss and have everything spin slower and work the same as before and that would free up a few horsepower. If there is nothing wrong wrong with them then just replace them with some unorthodox pulleys or something as you can afford them. I don't know if they make them for a cb7 but I bet they do. Like I said be more specific please. I don't know a shit load but i'll be more than happy to help with what I can.
      You're not even sure what parts you're talking about... so no. Don't touch a thing until you learn more about your car. You don't change the crankshaft without rebuilding the entire motor. It's located deep in the block.
      Unless you have a DOHC motor, you only have one cam... and one cam gear... You don't need to upgrade the gear unless you know how to adjust it (and have a dyno on which to do so).
      A camshaft upgrade often involves a valvetrain upgrade, which, again, requires taking the motor apart. You CAN do it without the valvetrain upgrade, but I personally wouldn't trust 16 year old valve springs to work well for very long.
      Pulleys... get them, and get them installed by professionals... Do the accessory pullies only, and you'll be fine... as long as you don't have a crazy audio system (as the alternator pulley underdrives the alternator, and it won't charge the battery fast enough to keep up with a big system). If you get a crank pulley, don't get anything but Unorthodox Racing. Sure, there are cheap pulleys out there, but factor in the cost of a new engine when they blow up your old one, and they end up being VERY expensive.
