pulley
    pulley
    do u guys recommend an underdrive crank pulley?? or the stock crank pully??
    i need some advice...thanx!
    Viciouzkiddo
    for astetics yes. but for "HP", Id save the cash for other stuff
    93 Accord LX Sedan (sold)
      I replaced mine just because I chipped the OEM when doing the timing belt. It was cheaper then the OEM and looks good, BUT I'd guess this is one of those things you do when your trying to get the last little umpgh out of a full racer. No noticable change on mine though.
        what about if you you change out all your pulleys to light weight........ will there be a significant change in throttle respons n hp??? i know that it makes a huge difference in the feel of the motor in civics and in my old golf but what about in cb's??
        DELTA CAM GROUP BUY
        http://www.youtube.com/watch?v=PSbCQuhAnNcla gringa pt.1
        http://www.youtube.com/watch?v=hMz-F2saG_ola gringa pt.2
          You don't really see the pulley, so there's no point in doing it for aesthetics.
          As far as a pulley upgrade goes, the crank pulley is the only one that really makes a noticeable difference.
          However, there is a risk of oil pump failure using one... which will destroy your motor.
          DO NOT get a cheap pulley. Unorthodox Racing is the only one that's worth owning. Unless you like the sound of an exploding motor.
