Ok so I just purchased this 92 Accord LX for cheap because it has a few issues. One of the main one being the speedo doesn't work and the s light is flashing. After some research on this site I determined it is a VSS issue and so I attempted to extract said sensor.
Then the epic battle began and in the end I had one bolt out and the bolt nearest the pass side stripped. I tried bolt out but the size that fit requires a 19mm socket which won't fit in that tight space. I tried everything I can think of but no luck.
How can I get that sucker out?
