Hub adaptor spacers????
    I was searching on my local craigslist and noticed someone selling an
    hub adaptor spacer. the ad said that i can convert my 4 X 114 lugs set up to
    a 5 x 114. Is this an good option to use a 5 lug wheel? I wanted to put the 5th generation accord v-6 5 poke rim or the tl 5 spoke on my cb. I just wanted to know if this was safe to use. thanks
    93 Accord SE
    02 Highlander Limited
    No way. It's for sale for a reason. Iv'e seen damage and potential death from such items. not cool. That's why I'm converting the right way.
    GOT F?
      good to know that was the first time i ever seen something like that.
      93 Accord SE
        They work if you use them for daily driving. When too much stress is put on them, they can snap. Not from the 5 lug but your 4 lug that is holding the 5 lug.
          It also changes the geometry of the assembly... pushes your wheels out pretty far. That can cause some issues.
          If you want 5 lug, do it the right way... that's not something you want to mess with. NEVER cheap out on suspension, tires, or brakes. Your life depends on tham. At least your engine, exterior, and interior (for the most part) are just an annoying expense when something breaks.
            I've seen these all over ebay lately, mostly the 4x114.3 to 4x100, and 4x100 to 4x114.3.
            I would be careful with these. Your lugs are designed to have a wheel directly on them, not some ebay adapter. I would save my money and do the swap the right and safe way.
            It is your car and your money so do what you want. I just would not expect anyone to have any sympathy for you if/when something breaks and you total your car injure yourself or quite possibly innocent bystanders.
              Bad idea...do it the safe way
