92 accord intake man swap
    im about to swap the intake mani this weekend but i need some opinion from more experience people
    this is what i have on hand:
    A6 RUNNERS
    2 SPACER/ONE WITH OUT THE B-FLYS
    H23 PLENUM AND H23 TB
    ALL GASKET
    I DON'T HAVE
    ECU (PT6) TO CONTROL B-FLYS
    IF I DO SUCH SWAP IS THERE ANY PROBLEM MIGHT HAPPEN.
    A6 RUNNERS
    ALL GASKET
    I DON'T HAVE
    Not if you install it the right way. For a double stack IAB, you will need different bolts. I'm not sure if you got those already. You will also need to extend all coolant lines and probably the IACV electric wire. You can hook the butterfly valve up to straight vacuum or just take them out of the mani you still have them on.
    PARTING OUT MY 1990 EX COUPE!! EVERYTHING FOR SALE! CLICK HERE
    Listen or download the first 4 songs I completed for my new upcoming album here!!
    My member's ride
      Originally posted by AbsurdNY View Post
      Not if you install it the right way. For a double stack IAB, you will need different bolts. I'm not sure if you got those already. You can hook the butterfly valve up to straight vacuum or just take them out of the mani you still have them on.
      I've tried time and time again (about a dozen times now) and I have NEVER been able to get the butterflies to operate with just intake vacuum. Ran it from idle to 6800 and they never moved. Even added small vacuum fittings to restrict the vacuum pressure and still no go. Maybe I just haven't had good luck?
      But to the OP, no there shouldn't be any problems other then what has already been said.
      Click Image for CB7Tuner.com Beanies, Decals, & Keychains!
        also try getting the IAB black box that mounts underneath the IM runners. It controls the IABs.
          the mani is in part whaiting to get in the car but i wana be sure and do it right. i need the bolts can i get them at home depot? how big are they?
          I dont' have IAB black box/PT6 ECU but still i will put it in to the engine later on i 'll get the ecu i also have the A6 cam but is too cold to work fo to long(i don't have the experience to do the cam) today i received the cold air pipe from Ebay looks ok!
            Just hook the IAB valve direct to a vacuum source.
            This eliminates the need for a pt6 for now.
              that is what im gona do for now. do you know if i can get the bolts from home depot? how big are they?
                You could also just remove the butterflies in both... You might lose some low end, but it'll very likely improve top end. I believe doing the stack increases low end already.
