Possibly a PS leak
    Possibly a PS leak
    So, I've found some fluid has been thrown onto the underside of my hood, and my PS fluid is kinda lower than normal. Added PS fluid, and it drained back down to the same level after a short drive.
    So, I think it may be leaking onto one of the belts and the belt threw it onto the hood.
    Anyway, what's something I can use to clean it all up without damaging anything?
    And, are there any common PS leakage issues to check for?
    Car is a 93 SE with a F22A1 (unfortunately) but only the engine, IM and everything else was kept from the a6.
    2000 Acura TL-P - Daily
    1993 Honda Accord SE - Sold
    1996 Infiniti J30 - Sold
    1997 Honda Civic EX - Sold
    1996 Saturn SL2 - Totalled
    1982 Mercedes-Benz 300SD - Sold
    1982 Mercedes-Benz 240D - Totalled
    Gunk Engine bright is pretty safe for the engine areas, for the hood I'd just use regular soap and water and try and scrub it down.
    Diluted simple green also works well on the engine, but you have to be careful with it on paint, it will eat the paint.
    I'd check for a loose hose first, then p/s hoses themselves, and if that is looking good then it's probably either the front shaft seal or the rear o-ring. I think you can find a kit for those parts, but it might be faster/easier to just get a good looking pump out of the junkyard. They're only $30 at my local one.
    1992 Prelude S w/swapped H22A
      underneath the engine, you will see some hard lines running into the steering rack, they will be covered with a plastic shield. The broken line should be there; its very common with CB's, when I got mine fixed, the garage had another CB in for the same issue. ...
      we cut off the old hard line and replaced it with a rubber hydraulic line. done and done.
      gluck
      DEVOTE
      FS: Lokuputha's Stuff
        Thanks, I'll look at that tomorrow. It's either there, or I think the pump might be leaking on the pulley side.
          Pretty sure it's leaking from the pump. Does anyone sell a gasket/seal kit to rebuild the pump? Or would it be easier to just get a new/used pump?
            gluck
            Exactly what happened to mine, and exactly what I did.
              Majestic Honda lists all of the O-rings and stuff, you might try getting them there. Like I said earlier, it might just be easier to get a good looking pump out of a junkyard rather than screw with the one you have.
