Changing distributer... NEED step by step instructions
    Im replacing it in order to fix the car. I have 4 and 15 CEl but i need exact instructions how to do this. Do you have to reset the ecu after??
    http://www.autozone.com/shopping/rep...00c1528005f511
    make sure new O-ring is installed http://www.cb7tuner.com/vbb/showthread.php?t=88245
    Reset your ECU by taking out the ECU Fuse and Put it back in. That should reset the code also.
    You might have to set the timing also. Since the timing will be off with new distributor. (you need that special gun...i would take it to the shop and have them adjust the timing)
      You WILL have to set the timing after.
      The light is $40 from most autoparts stores. A shop might charge you half of that, and you won't have a new tool. I say just get the timing light. Charge your friends $5 to use it
        http://www.cb7tuner.com/vbb/showthre...ight=reset+ecu
          Really? dang.. With that being said I will get my timing retimed then.
          When I changed mine I just installed the way the old one was positioned , including the rotor position. I did not time it. So it's retiming for me.
          Sorry for thread jack.
          1996 Honda Civic LX 2009-2012
          2012 Kia Optima LX 2012-2013
            I've been told that you can't do damage by having our distributors set to the extreme in any direction... but I'd still not risk it!
              True.
                whats the best timing on the h22? can it be advanced a lil?
                  It depends on your engine, honestly. You can advance and retard safely within 2 degrees of stock... those points are marked on the flywheel, and easily seen with a timing light.
                  Changing the timing can move the powerband around. Generally, the stock 15 degrees is where you want it.
                    I recently picked up a timing light to figure out why my car was running like ish after a new water pump and dizzy. We tried our best to align to the marks but it didn't go so well, there were two lines in our sights, one longer than the other... Which of these is the stock 15deg BTDC line?
                    We ended up rotating the dizzy all the way to one direction and it made it run right(well, doesnt act sluggish anymore), but I know that's not the "proper" way to set it..
                      ok then ill just stick to 15*
