squeeking when turn?
    whenever i turn at all i hear a very loud squeeking noise.
    im not sure as to what it could be.
    anyone have any ideas?
    i need to know.
    thanks!
    Sounds like either a tie rod end, or maybe your axle
    SOLD!!
    Boosted H22
    375whp 298 ft/lbs at 15psi
      i always thought that squeeking had something to do with power steering no?
        when you go over little bumps or when you push ur car up and down(front) do you hear the squeaking noise??????
        if yes then that is a lower ball join problem......
          my car dose it too after i put my 90 steering wheel in.. it go's wooooooooooooooooooooooooooooooom pulling in my drive way.. ITS NOT BALL JOINTS.. its either your low on fluid or its somthing in the colmn
            somebody told me my fittings needed greased is this acurate?
            or bearing and bushings?
              Yes your bushings might be finished and need to be replaced, or if they are still good it wouldn't hurt to grease them. But that porbably won't stop the squeaking
              SOLD!!
              Boosted H22
                my first cb does that.....I found out it need new stabilizer..
                you can always check that...
                  so really what should i look into replacing?
                  besides my whole car :P
                  ik thats a good idea but i cant :P
                  SOMEONE PLEASE HELP!
                    you have to be more specific of the noise.... does it do it only when turning in full? does it do it when you drive over little bumps???
                    check the bushings, check the ti rods, check the lower ball joins etc etc etc....we can't just tell you that is a specific part or thing just by the noise that you are describing....
                      yup...just check all the above as mention....
                        loose/worn power steering belt
                        Originally posted by kc8enb07
                        does it come w/ jdm trash? they better throw away gold in it
                          Are you talking about a moan of some sort? I had the same problem a while back but it stopped completely.
                          I was driving and while going 30 at a 15mph turn, i lost traction and skid towards the curb. The toe in the passenger side was in and all i needed was alignment. Days later the moan never came back.
                          I wouldnt suggest drifting into a curb but someone might suggest a diagnosis from my experience.
                            lower balljoint is bad and also i have a hole in my oil pan. just great eh?
                              i got my cb7 checked today and they said the boot in the front is ripped,
                              they greased the boot and the loud squeeking went away, whats that boot called? they said greasing it wont help much because the boot is ripped so all the grease will just drip and become dry again, i would much rather buy a new boot then buy a whole new lower ball joint.
                              whats the boot called?
                              someone help please?
