i found a h22a4 just the complete block for $400 dollars it has a spon rod bearing is this a good deal?
h22a4
"it has a spon rod bearing"Originally posted by Dans92cb7 View Posti found a h22a4 just the complete block for $400 dollars it has a spon rod bearing is this a good deal?
Not a real question.
Sit back and think about it. Do the math, what do you want??????????
Nothing happens without a commitment, sounds like fun to me but not for everyone.
Usually spending a little more will get ya a lot more.
math
Take that freek show to the park, maybe the squirrels will care.
If you're putting JE pistons in an H22, you're going to have to resleeve it. The H22 has FRM sleeves that are not compatible with standard aftermarket pistons.
It MIGHT be worth a rebuild. It's hard to say what sort of internal damage is done. If it spun a rod bearing, the cylinder walls may be scored, the crank may be damaged, the head may have taken damage if the rod pulled loose. You never know until you crack it open.
For $400, if you WANT a rebuild project.. it might be worth it. It all depends on you. It's going to cost more to rebuild this motor than it is to find another one in running condition. However, a proper rebuild can be much better than an old one.
thanks u might be right ill pass on that deal....Originally posted by deevergote. View PostIf you're putting JE pistons in an H22, you're going to have to resleeve it. The H22 has FRM sleeves that are not compatible with standard aftermarket pistons.
it alittle too much talk it downOriginally posted by Dans92cb7 View Posti found a h22a4 just the complete block for $400 dollars it has a spon rod bearing is this a good deal?kiss my grill
Members Ride
