Tail light issues
    Tail light issues
    On my 92 Coupe my drivers side tail light keeps filling up with water, any suggenstions on how to seal it up? I tried but apparently it didnt work.
    http://s373.photobucket.com/albums/o...=honda2-1.jpg][/URL][/IMG]
    if you're super patient you can use a heat gun to separate them completely and then reseal them.
    OHIO CB7'S #11
    SOLD
    Members Ride DevlTuning
      Either use clear silicone or a hot glue gun, they both work well. Just run your bead along the upper and side seams to seal the light up. Also before you start take a heat gun or blow dryer to the taillight to get all of the moisture out. Later.
      Still hustlin that Old Skool.......it never ends.
      vv My Member's Ride Thread vv
      http://www.cb7tuner.com/vbb/showthread.php?t=123371
        Yeah I used silicone on mine, I just ran it along the top, and have not had a problem since, but i do have a problem with water in my damb trunck for some reason?
        Can I get a Hell Yeah!!!
          Your weatherstripping are done.
          1996 Honda Civic LX 2009-2012
          2012 Kia Optima LX 2012-2013
            I will try to re-seal them again then. Thanks guys. Oh and the water in the trunk problem is probably because of the gasket between the tail light and the body. EXR-ALB has the same water in the trunk problem, we think its those gaskets.
              those gaskets are notorious for leaking
              OHIO CB7'S #11
              SOLD
                yeah my trunk leaks like crazy and I might have to take appart my tail lights too. They get foggy =/
                  well at least i know its a common problem and not only me.
                    i might just get a new light if it doesnt work.
                      Yeah its the gasket behind the light.
                      wat?
                        I had the same problem...
                        First, remove your lamps, make sure they dry (use a hair dryer, or whatever you have)
                        I ran silicone the whole perimeter where the lens meets the housing, and smoothed it out with my finger to make it look neat.
                        Then I drilled a tiny hole on the inner under side of the blinker / indicator to let whatever water that gets in, drip out.
                        Mind you, you want to keep those lamps dry because:
                        a.) your brake lamp indicator will come on on the dash even if you have all bulbs working.
                        b.) still water will start going murky...
                        HONDAMENTALISM
                          Maybe moisture might be the problem of my fiance's CB7, cause i have tried everything to try to make the brake light on the dash go out. I change the pigtails, the electronic box, and the bulbs, and it still does it. Ithink I will drill a hole in mine, cause I dont reall want to buy a new tail light.
