91 motor 2 92 motor
    91 motor 2 92 motor
    well i know my 91 motor gots an internal coil... and the 92 has a external coil.... would i have to rewire something? change the computers? or what?
    CB7_HULK SMASH!!!
    nope man it will be fine
    back at it again
      o yeah byt the way im not changing the whole motor just cuz its external coil i know i can just make mine external.. i think my motor is gone so ima get another one but u know how the people from the yunk yard are they just give u anything from a 90-93
      CB7_HULK SMASH!!!
        so u have a 9091 correct and yes you may end up with a 9293 motor if you go to the j-yard. the wirering should be the same man.
        back at it again
          if it means anything i have a 92 motor with a internal coil but i learned it wont start unless u have at least the external coil pak hooked up from the harness.
          hmm would a 92 with a sohc vtec be a si????? might as well be
            yeah its a 91 ex sedan..... sunday the oil pump went out and started knocking but i turned off right away.....
            CB7_HULK SMASH!!!
              thats correct. You will need a 92-93 harness
              Hold On Not Done Accelerating
              Had One Never Did Again
                get a mini msd coil.
                back at it again
                  what u mean creeper? how u got a 92 motor with an internal coil?
                  CB7_HULK SMASH!!!
                    ok ok wtf? so what do i need?
                    CB7_HULK SMASH!!!
                      Just use your dizzy
                      wat?
                        so if i put a 92 motor on my 91 ima have to change my dizzy? i-07 said it'll be alright?
                        dont you hate it when u get two opposite opinions?
                        CB7_HULK SMASH!!!
                          but i aint 100% on that lol i said it sould not will lol. i have a 92 you see with a ext coil
                          back at it again
                            ummm te digo.... (umm i tell u).... then i guess if it dont work ima really have to change the dizzy
                            CB7_HULK SMASH!!!
                              yup
                              back at it again
