My brother's 92 Accord is shifting hard through all the gears. It's an automatic, It shifts through all the gears normally but shifts hard through them. Someone told me the fluid needs to be changed, while another said the motor mounts can be gone?
1992 Honda Accord - rough/hard shifting
Originally posted by Gotenks64 View PostBoth can be the problem are you using Honda Tranny Fluid? If not try that, and in most cases it is the rear engine mount that goes bad.
Originally posted by StinkinLincoln View PostWhere Can You Buy Honda ATF?? Our Shop Doesn't Have It...Autozone mabe???DEVOTE
FS: Lokuputha's Stuff
Ya, the trannys in our cars are not the smoothest and it also has a lot to do with the way the car is driven. This is evident when shifting out of the first gear, without modification there not made to jump hard right off the start. In these cars u can always feel sort of a rough shift between gears, but if it gets progressively worse ur best bet is to change the rear mount. Also, is the car shaking at all while moving or when at a stop?
