penzoil 10w30 no preference just what I had in my shed.
what oil you run?
Ive used...
royal purple
penzoil Synthetic
& now Im using Castrol Synthetic
93 Accord LX Sedan (sold)
mobile 1 10w40 with matching filter.
heard pennzoil leaves residues and is bad for motors a few times different places.
i dunno if royal purple is even worth the effort to find it, pay for it, and look for a difference in power especially if your motor isn't banging or boosted.
honda oem tranny fluid.
we can use the S2000 filter?Last edited by nostringz; 12-16-2008, 02:05 AM.
Yeah I wanted to know about that too. S2k filter fits what motor?Originally posted by nostringz View Postmobile 1 10w40 with matching filter.
we can use the S2000 filter?Insert Lame Comment Here.
i put nothing but the best and in my opinion its ams oil with a k&n or mobile1 filter
92ex coupe h22
93 240sx with silvia front end (kadet in the works)
http://www.cb7tuner.com/vbb/showthre...=1#post1894990
I use Mobile 1 in everything (unless I have an aftermarket LSD, then I usually use the fluid the manufacterer designed for it).
It mostly comes down to personal preference as to which brand is best. And as far as synthetics go, yes, they are SLIGHTLY thinner. So on higher mileage motors, just up the weight of the oil slightly, and it shouldn't really be any problems. It's better to use higher weight oil in older/higher mileage engines anyways, because it helps seal better (giving better compression), helps fill in the microscopic gaps left by years and miles of friction, and also helps lessen wear and tear rates from friction anyways.
Royal Purple when Amsoil isnt available. I also run an Amsoil filter.
