hood will not close
    hood will not close
    hodd locks but will not close all the way any ideas anyone
    BK ALL DAY
    how big is the gap?
    hood latch/lock is held by 3 10mm bolts.. remove the grill and you should have access to it.. loosen and adjust..
      i got the same problem.. but im pretty sure this car has been in a front end accident. ill try the hood latch tomorrow tho.
        have u done anything recently to the car? Reason i ask is the last time that happened to me it was because my headlight were clinching the cable for the latch after reinstallation. Check to make sure u cable isn't caught anywhere.
        Summer 11' Big plans (Bodywork/paint/rims etc..) in Progress STAY TUNED
        CLICK THE PIC
          its a metal right in the middle of the grill dat u have to push down in order for the hood to lock again. i have to do it to mines everytime i open it
            there are some rubber knobs on your radiator support near your fenders that can be turned down to give you better clearance.
              Check your hoodlock
              1. remove your grill
              2. try to close your hood again, but watch the hoodlock (located where your grill used to be)
              or :thumbsdown:
              Be Clean
                I say jump on top of the hoodj/p
                My ride History:
                Accord 90 lx auto: Gone
                Accord 91 dx MT: Gone
                Accord 92 lx auto: Gone
                1st to D.I.Y custom RED/CLEAR's
                  maybe leftover tools or parts, i know(capt obvious).
                    I'd second this as well. My hood release cable was partially seized due to rust build up so I had to keep pushing down on the metal tab on the hood latch. It's got a spring hooked to it. The spring usually pulls the latch back but with the bad cable, I had to help it by pushing it down. Replacing the release cable fixed my problem. Actually happened on 3 CB's now that I think about it.
                      100% correct
                      look to left of the actual latching piece. you will see a metal arm with wire on it, press hard on it and then it will work
                      smoke tires, not drugs.
                        My wife's Civic had the same problem. It could mean the latch is out of alignment with the loop on the hood. Try reaching around it and pulling it up a litte by standing in front of it while facing the engine bay. Put your hand on the bottom of it by reaching over it, then pull up a couple decent tugs. That's how we got my wife's to work. It's worth a shot, take a few seconds to do, and doesn't cost a dime.
