Why does my 5th gear grind? Do I need a new tranny? No other gears grind just 5th.
grinding
Probably synchros going bad into fifth gear.
You can replace tranny fluid to preserve the tranny. Just be gentle going into fifth and try to match the revs when you put it in. Depends on how bad the grinding is but you maybe be able to shift with out it grinding if you do it right.
You don't NEED a new transmission.
Have you checked your tranny fluid? When was the last time it was changed? If you can't remember/don't know then you should probably just do it. There is a thread around here debating the best oil to use; Honda says use regular motor oil, some people are going for GM Syncromesh, etc. If you go with regular oil, I'd go for at the very least 10W30. 5W30 is a little too thin IMO.
Also, how is your clutch? As you get to the end of it's lifespan, it gets slightly tougher to shift.1992 Prelude S w/swapped H22A
GM Synchromesh or Honda MTF (synthetic) are the best options, especially for a tranny that is already failing. The fluid change won't fix anything permanently but it may prolong the life of the tranny. 5th gear isnt too bad. I had 2nd and 3rd go on me in the past. Just don't shift fast into 5th. mine grinds now. no biggie.
Mine is doing the same thing. It's original '93 with 230,000 miles on it. The only way I can keep it from grinding is to hold the clutch longer, and slowly move the shifter into 5th. I put a new clutch in, and changed the oil not long ago. Waiting to save some cash to completely rebuild it with new bearings, syncronizers, and probably even the shifter forks. Looking at LSD kits too. Alot of the money comes in the different thicknesses of shim washers you have to buy to get the clearances right, rather than putting it together, measuring it out, then having to stop and go order the sizes you need to put it back together right.My inferiority complex isn't as good as yours.
