Alright. Major Ecu Problem
    a while back i was driving in the rain, i made a uturn and jumped on the throttle, my car wound up like usual 4k. then made a sputter, and a massive Bang. i have no idea what could have caused this, rolled into a parking lot, and played doctor. i investigated and my ecu fuse was blown, this happened again when i was jumping on the freeway, lo rpms this time. blew another fuse, i replaced it with the only fuse i had. a 25, it tried it again, but the fuse didnt blow, wtf is going on with my baby!!!
    Sounds like you have a short somewhere.
    BTW, it is typically reccomended to NEVER replace a fuse with one that is a higher amp than the original. That could actually cause you to fry electrical systems (which are much more expensive than replacing fuses all the time), or cause fires.
      very true.
      also this is not an ecu problem. something is grounding out. look for frayed wires somewhere.
