can sum1 tell me why my cars at 3000 rpms at only 65 mph? the (S) light blinks. i hooked up a jumper wire n it read off a code 9. sum1 told me replace the distributor n i did.. still got a code 9. can ne1 help me with this situation? i cant stand the car being like this cuz i never really feel safe driving constantly at 60 mph.. i dont wanna push it 2 hard cuz itz got 320,000 miles on it. any help would b grealy appreciated.
3000 rpms at 65 mph?
well i did get it from the junkyard.. i just dont wanna put tha money in2 a new distributor if it is just the wiring. but i guess ill try a new 1.. if that is the problem should the car run regular? (if there are no more codes given off)Originally posted by scudweiser View Posta code 9 is the no.1 cylinder sensor, which is in your distributer. if you already replaced it check your wiring.
i just spent a week doing ignition wiring work so im feeling pretty comfortable with it lol.
there should be a harness with 7 wires coming out of the distributer to a connector in the front of it.
the wires are: to ecu pin#
orange/blue B13
blue/green B15
orange B11
white/blue B14
white B12
blue/yellow B16
your ecu is under the carpet in the passanger side foot area towards the firewall
check these wires using a resistance (Ohms) meter to make sure theyre making a connection from the dizzy to the ECU
the crank angle sensor helps generate a speed signal, so that may be why it wont go into overdrive
hope this helps
yea if any sensor in the dizzy goes bad you need to replace the whole thing, but id say check the wiring first, if i had done that i would have saved myself literally hours of frusytration this week. good luck budday, and i have a Chilton and Hayes guide for accords if you need anything looked up.Originally posted by igot310s View Postwell i did get it from the junkyard.. i just dont wanna put tha money in2 a new distributor if it is just the wiring. but i guess ill try a new 1.. if that is the problem should the car run regular? (if there are no more codes given off)
You guys are misleading the OP:
Code 9 for Auto Transmissions is not the Cylinder Sensor, it's Code 9 - Counter shaft or transmission speed pulse generator open or shorted.
ECU and TCU codes are totally different. "S" or "D4" light will give you a transmission code. In addition , the CEL will light for the Cylinder code.
In his case , it's the "S" for the TCU code.Last edited by ExplodingCake; 12-23-2008, 11:05 PM.
1996 Honda Civic LX 2009-2012
2012 Kia Optima LX 2012-2013
crap, my bad, i must have just read over his post too fastOriginally posted by Cakeboy View PostYou guys are misleading the OP:
Check this thread for your code. Replacing the distributor is if your Check Engine light were to come on, not your "S" light. Here are your TCU codes... http://www.cb7tuner.com/vbb/showthread.php?p=1394464Originally posted by Junior SmurffNevermind guys, google search works wonders!
I don't have road rage, my car just goes faster than yours!
Accords are for winners. And Grandmothers. But mostly winners.
I have grown so Tired of Internet Illiteracy. Please learn proper spelling and grammar. For your sake and that of your children.
you'll love my nuts!
