sup everyone here's the issue... i since i bought my 93 ex two weeks ago i already noticed that the starter was cranking weak...eventually after driving for a couple of days it got to a point that it would struggle to crank, and then it died...i checked my battery and alternator with a diagnostic tool and they were fine...the starter would turn but barely like it slow motion....so i got a rebuilt one changed it out, made sure to connect both wires to it and to reconnect my battery terminals....and now it does'nt even try... all the lights on the dash light up but nothing...i made sure my neg terminal was grounded right and that none of the wires came loose in my fuse box....i'm stuck please help!!!
Thought starter was bad changed it and nothing please help!!!!
Have you had your battery checked out and its fully charged, I ask because I saw you talked about testing the starter with a dia tool and I think the alternator. Also there is a ground next to the fender coming off the battery if that's not connected well it may give you a slight problem starting, I know I had the problem.
got it!! even though the battery tested good with the tester i had at home...Godchild came to my crib and ran a jumper from the battery positive directly to the starter and it tried to crank but all the lights went dim and then i figured to check the battery at advance...i went and the damn battery was bad!!! so thanks to Godchild he had a spare red top optima and now i got new optima and starter
and boy does it crank nice
