battery tie down
    battery tie down
    are the accord battery tie downs (aftermarket) the same as the civic/teg?
    bump i want to know too.
      Should be.
      I use bungee cords.
        Should be.
        I use bungee cords.
        come on deev i thought you were the most serious out of many.
        i am thinking in my head to see if the neuspeed license plate cover plate will be functionable as a battery tie down.
          no, they use a super small battery that goes on their fire wall
            damn i really want an aftermarket battery down. but not those hayami ones or no brand-er.
            i was looking at the -password or the -skunk2
            fudge...........................no one fits?
              well the batteries arent the same, but I think the aftermarket ones are made to fit the bigger ones like we use. some member in socal has a DC sports tie down and it fits just fine..
                you know where i can get one?
                how does it look like?
                  It's a battery tie down... it just holds the battery in place. What do you need a name brand for?
                  And have you seen my car?
                    do you even have a car?
                    ill check it out right now
                      -Fresh coat of Phantom Gray (7/01/06) (thanks to Maaco )
                      -JDM 1 piece lights with an Audi HID projector retrofit (thanks to icedplaya123 and iceking66)
                      -17" Bronze Falken Hanabi, Falken Ziex tires.
                      -Red valve cover w/ mooncuts (thanks to DrLove'sKuDang)
                      -Custom bronze plug cover. (thanks to 93twodoorLX)
                      -Colormatched grill (professionally painted) with a bronze mesh insert.
                      -Fiber Images OEM style Carbon Fiber hood (thanks to 90cb7beast)
                      ---Engine & Performance---
                      -JDM H22A (1994) swapped in at 166,000 miles. (hmotorsonline.com)
                      -AEM CAI (Prelude. Yes, it fit perfectly)
                      -Custom 2.5" exhaust system with dual-tip stainless muffler
                      -Unorthodox Racing crank pulley
                      -NGK Irridium IX plugs
                      -95 P28 ECU, chipped and tuned (in person) by MRX
                      -3500 RPM full throttle launch (thanks to MRX)
                      -Fushigi Race Engineering short shifter (thanks to elchulo583 and fushigi RES)
                      -NGK Blue plug wires (thanks to elchulo583)
                      -XTD Stage 3 clutch and 12lb flywheel (thanks to cp[mike] and doctorcipher for the installation help!)
                      check out your car for what?
                      there is no battery tie
                        I didn't say check it out. I asked if you had seen it. It's hardly remarkable. My time and money go into this site, not my car, sadly.
                        As I said, I use bungee cords. I'm not lying.
                          like leading a horse to water
                            Being that the Accord uses a larger battery than both Civic's and Integra's, the bracket is different. I believe you should look for a 92-96 Preulde application as far as a cross over option.
                              move it to the trunk and use a relocation kit, there's a few name brand relocation kits out there
                              91 EX Coupe 5 Speed
                              My Ride Thread
                              ASE Certified Master Tech Since 2005
                              That's like watching a guy stick his head up his own ass. Impressive... but why?
                              Bought From: Quakerjoe , MikeW
