2 problems wit my cb7
    My damn cb7 keeps giving me problems but i guess it'll be worth it when the problems are fixed right guys??....
    On to the problem,ok first off whenever im driving and im hittin passed 60 mph my car starts to shake, well my steering wheel?? what can it be my bro told me it might be that one of my tires could be flatter then the others hmmmm??
    Second problem has recently occured, whenever i change from 1st to 2nd it begins to choke like if it doesnt grab 2nd or something... could it be that my clutch is going??
    For the shaky steering wheel it could be that your tires aren't balanced properly, that is usually the cause of a shaking wheel at higher speeds, as for the choking while changing gears that could be a few problems, but if your clutch is slipping you can tell by changing gears from 1st to 2nd or 3rd to 4th and right after you change gears hit the gas and watch your rpm gauge. If the rpm needle moves up when you hit the gas and your not really going anywhere speed wise, then your clutch is slipping. But the choking could also be due to your egr valve, could also be your ignition (spark plugs, wires, cap, rotor)
    SOLD!!
    Boosted H22
    375whp 298 ft/lbs at 15psi
      yea thats wat my bro was telling me about the shaking and the when i switch gears the rpm's are just fine but yea the mechanic at my job was telling me something about some fuel injection cleaner somethin like that couldnt quiet understand his accent but hes a truck mechanic too he tells me that stuff is different so he couldnt always be on point with the problem
        19TcappaLX
        shaking might be coming from a bent rim or bad ball joints.
          For the first one tire balance or a bent rim and the second one it could b a fuel problem, the only thing is that it'll happen all the time not just from 1st 2 2nd.
            definantly balance tires or bent rim i had the same problem with a couple of cars and that fixed it
              my car did the same wen i use to go 60mph... Just get tires balanced
              If dat does not fix the problem then you need an alignment
              Thats what i am bout to do next
                yeah get the wheels balance at a place with a high speed balance machine.
                  For your first issue, I would suggest either a tire balance (like everyone else) and/or an alignment. For the second, I would also check the RPMs, make sure your spark plugs & wires are good, check the EGR valve, and invest in some SeaFoam for cleaning your whole fuel system!! (pour it in your next full tank of gas... it's like $7). Good Luck and keep us posted.
                    wow! nice sig bro! i hope its turboed!
                      buy a 1-dollar chocolate cookies from giants. ask for the receipt and u'll get a promotion like oil change, tire rotation and something for only 17 bucks! (well, we have that in my area)
