shaking problem
    shaking problem
    My car shakes a lilttle bit when I step on the gas but once I'm at a steady speed it stops what could it be ?
    Does it do it when you apply the brakes?
    Maybe a bad motor mount? does it make any clunking noises?
      No clunkin but it does shake a lil and I push duh brakes
        sound like bad rims,i had that problem with my stock rims,try getting them balanced first.i had three rims bent when i got my cb7.
          How could I tell if the rim is bent... and I just had my tires balanced and rotated
            I had this issue, the problem was coming from old, warped drive shafts. After I put in two Honda OEM drive shafts, the issue went away.
            DEVOTE
            FS: Lokuputha's Stuff
