Ok this is what happen to me like two days ago. I had a leak in my by pass hose that connects to the therminstat my dumb @$$ diside to take the distributor off. That was the only way that i could fitt my hand to get to the by pass hose. Can any body tell me what should i do to get my car started. please any body help me out i miss driving my cb7.
distributor?
Most likely your distributor is not sitted right on the camshaft or most likely you distributor rotor is rotated 180 degrees off. I would take out the distributor again and rotate my crankshaft to TDC (top dead center). Take off the distributor cap and rotate the rotor to point at where the #1 ignition wire plugs in to the cap. Put back the distributor back to the head, put back the cap, then put back the wires and see if she fire's up. I would suggest getting a haynes manual if you are doing this the first time.
im pretty sure there it a rubber ring on the distributer that prevents any oil from leaking out but i could be wrong.Originally posted by drift878 View Postok now guys i got my car started like 3 weeks ago. now i am having a lil oil leak i justed did my valve cover gasket. i think its the distributor. does the distributor have a gasket that u have to put between the distrbutor and the motor?
first make sure your dist is lined up with the cam shaft, there are 2 square teeth on the dist you have you match them to the grooves on the end of the dist.
Second there is a wiring harness, make sure you have that connected and SEATEd correctly.
Third, would be the most stupid*cough* i mean newb reason....
you spark plug wires are probably hooked up in the wrong order.
Im at work or i would insert a pic of the dist i have on my photobucket
go to http://www.photobucket.com/slice5k you cant miss it its the picture of the dist with numbers on it.
also check your No.2 15 amp fuse underdash._____________________________
91 Accord F22B
