Im in the process of doing an auto to 5sp. swap in a 91 ex. My question is, can I use the stock auto rear motor mount. I do have the 5sp. rear T bracket. Just wondering if I need to change both out or not.
5sp. Swap motor mount questions
you can use whichever rear mount you want, as long as you pair it with its matching rear T bracket. i would recommend the 5spd one though, as its smaller, simpler, and most importantly more solid. plus its lower height makes it easier to work with the shifter cables.
