Setting up the spoiler
    can i run the harness back in the trunk to the third brake light?
    Does the spoiler have the light? If so just connect it to the brake light wiring for the taillights.
    91 Accord Ex
    97 Civic Ex
    91 Crx B16
      Response...
      Good idea to wire the wing LED's to the back dash light harness. We won't want both back dash light and wing light on at the same time anyway...that looks so lame.
      I have the factory wing but just haven't mount it yet. ( Car black, wing dark burgundy) I have a 93 coupe so I'm torn between the 90-91 trunk with red clears or the stock trunk with stock tails. ( I did the trunk swap but but trunks a pool from the seals around the outer tails. I need to fix the water problem with the seals and perhaps use some clear silicone around the top of the light to divert the water.
      Respond with pics of it mounted when you do !
      Take care,
      A
