Clutch Line
    Clutch Line
    http://www.tasauto.com/Product/Browse.aspx?d=1618&p=1
    Is this the same part (191300) as #15 in the diagram
    Yessir.
    wat?
      Yep.
      http://www.cardomain.com/ride/2418752
        sweet thanks! do I need any special tools to replace?
          Don't think so, but you're supposed to replace parts 4 and 5 as well. A flare wrench might help with removing part 14 from the clutch line.
            Thanks, I think #5 is the banjo washers that comes in the TASAUTO kit.. and #4 is the banjo nut? I think, I may have to reuse.
              #5 is a crush washer. You can probably live without replacing, but it's cheap, so I would just do it anyway. I don't know what a banjo nut is, but I would think there would be a crush washer on each side of the line.
                that would make sense.. anywho I just hope that where my leak is coming from, and do ya think I really need a special wrench to get this apart?
                  You might. Try without first. If you can't get it loose without rounding the corners, you'll need a flare wrench. I know I needed a flare wrench when I removed my power steering line. They have the same type of connector.
                    I bought this line from them last spring and the line do comes with the parts 4 and 5. And if you buy it, make sure that the end fittings on the hose are tights cause mine were a bit loose when I received it.
                      ok I'll check that thankx
                        REALLY BIG BUMP SORRY I LOOKED FOR A DIAGRAM THOUGH!
                        What is number 13?
                          number 13 in the diagram above is the hard line that stretches from the CMC to the dampner on the passenger side.
                          you should be able to order that one still from Majestic but not number 14. that's discontinued.
                            another option is to use a whole braided clutch line that replaces the whole thing from the cmc to the slave. chasebays has them for 70 or 80 i think.
                              Here's my issue. There is a hard line that goes from Master cylinder(Next to the reservoir and near the brake reservoir on the drivers side) through the fire wall and up near the air intake(Below it) and that line burst.
                              Now when we patched it(Rubber tubing with clamps) it didnt leak at all. But I couldn't get any pressure through the line.
                              When I took off the bleeding screw on the slave cylinder there was barely if any brake fluid coming through when we were pumping the clutch.
