i am really hoping it's not the switch. i swapped the blower assembly (motor, resistor, housing, etc.) and it still doesn't work, but the recirc motor is moving.
i checked the fuse under the hood and the dash. i still have to check for voltage at the connector, but the psgr side door is up against the wall in my garage and i cannot get to that just yet.
are there any other likely culprits? i don't want to pull the dash trim to check the switch unless i absolutely have to. i don't know how to check relays, but i imagine that would be next. the motor does not work in any speed. i know it shares a ground with other items and those are working.
the car had a lot of lights and accessories that were not working when i bought it and this is the last item on the list. any help would be appreciated.
you'll love my nuts!
