I raced an 07 honda ridgeline last night and barely lost each race. Can i run premium with octane booster in my car?? If so, would it make much of a difference?
premium with octane booster?
ive never seen unused fuel come out the exhaust before. i use premuim in mine sometimes and runs fineOriginally posted by Charrdcb7 View Postunless u have shit done to your engine anything higher than 87 is just going to burn to slow and will end up depositing right out your tail pipe. It does not matter how high the number is on the pump, our engine is designed to run on 87, it would be a waste to put anything higher in it.
as far as adding octane boost to it, i wouldnt do that, dont know how safe that is for your car and your seals and stuff. if you really want to beat the ridgline then just add some deccent mods I/H/E.......h22? thats always a good upgrade. or just make sure your car is running good, do a tune up.
^^^^ me trying to kill myself after i saw the gas prices.
MY H22 COUPE ---> http://www.cb7tuner.com/vbb/showthread.php?t=75025
You have never seen raw fuel drip out of a tail pipe...?Originally posted by ignatsh22 View Postive never seen unused fuel come out the exhaust before. i use premuim in mine sometimes and runs fine
no....ive seen condesation from the exhaust but no raw fuel. i used to have an rx7 that shot flames sometimes but thats a whole nother topic.Originally posted by Charrdcb7 View PostYou have never seen raw fuel drip out of a tail pipe...?
A motor would blow up before you would see fuel dripping out of the tail pipe. You must be thinking of condensation.Originally posted by Charrdcb7 View PostYou have never seen raw fuel drip out of a tail pipe...?
I would never run octane booster. It gives your exhaust a funky smell and it doesn't really work. It makes your spark plugs red too.
Higher octane is ONLY needed when your current fuel has gone to the point where you're limiting power due to detonation/pre-det.
Even a camshaft upgrade on an f22 doesn't need higher octane, unless the ecu is tuned for it.
Correct, as was just stated by Mr. d112crzy
Higher octane means more resisitant to detonation. Hihger octane is less likely to ping and cause knock and predetonation. Unless you tune your car for higher octane, there will be NO GAINS from it.
Turbo cars and nitrous and high cr n/a cars pick up power from race gas not because its higher octane, but because the higher octane allows for the car to be tuned with more aggressive timing.2010 Taurus SHO - Livernois Goodies
You do emit unburnt fuel from your motor; this is what the catalytic converter attempts to burn, as not to allow this vapor to enter the atmosphere. If your converter isn't up to temperature yet, such as when you just start the car, you're exhausting unburnt fuel from the tail pipe. You should be able to smell this.
Octane Boost only works on the lower numbers of octane. It will increase it by maybe a point. On higher octane ratings like 92 and up it is useless. They have had quite a few tests done in magazines and on tv to show that it does nothing to help in horsepower. And remeber if you use any gas 100 or over here it will hurt your cat.
