Removing Heat Shield
    What is involved in removing the heat shield from the exhaust manifold ? (F22A1) It's nasty looking and I want to clean it up.
    Do I have to pull the O2 sensor ? Can it be manuvered out of the engine compartment ?
    Thanks
    i think theres three 10mm bolts (if they havent welded themselves to the shield already), you should be able to manuver it out just be careful of the 02 sensor wires. Just hit the head of the bolts if they have welded themselves to the shield.
      No...those bolts are no problem, they turned out with no problem.
        oh mine were all mis shaped and pretty much welded themselves to the shield
          just removed mine shield i had to remove the 02 sensor also.it was a little tight to get out.
            yea i agree with everyone the o2sensor was pritty tough wen i swap my headers. other than that the bolts was easy.
            P.NO president of mixed breeded family car club.
              All you have to do is angle the heatshield on the sensor then pull it out.
              Removal of sensor is not neccessary , however you have to route the harness.
              1996 Honda Civic LX 2009-2012
              2012 Kia Optima LX 2012-2013
                Great, that is what I was hoping for. Many thanks
