fuel rail: location?
    i tried searching, keywords: fuel rail
    and got every result imaginable except for anything fuel rail related lol.
    where is the fuel rail located and how can i disconnect it?
    My 1992 honda accord LX 5 spd.
    "Behold! What was once thought to have been
    buried beneath the sands of time,
    the ill-fated Haynes Repair Manual has been resurrected
    from the depths of a watery grave." - LX_Accordian
    Are You Kidding?? I'f not why would you really want to mess with the fuel rail??
    Trace your fuel flter the line that comes off it runs right into the fuel rail on the motor...
    1990 Accord LX Sedan~Sold
    1993 Accord EX Sedan~Sold
    1995 Suzuki GSX-R 750~Totaled
      This is a pic of the fule rail, circled in blue:
      And this will tell you pretty much how to remove the fuel rail:
      http://www.cb7tuner.com/vbb/showthre...light=injector
      1992 Honda Accord Coupe LX
        awesome.
        you are a god...
        thanks man!
          lol, glad i could help!
            Any reason for asking this? If you're looking to upgrade to a different rail, you'll really only be doing it for looks. No performance gains will be had from a fuel rail upgrade.
            vinbon63, that has to be the most helpful post ever!
              hey man,
              what i'm trying to do is simply disconnect the fuel rail to check and see if the fuel pump is pumping gas. what step do i follow for a brief disconnection, not a complete removal?
                Look at the fuel rail, follow it to the left. You will see a bolt with a metal line coming out of it. Thats what you want.
                wat?
                  Hey thanks, Im glad to hear that lol! My circling and arrow came out a little wierd but I guess clearly enough to see lol.
                    Originally posted by LX_Accordian View Post
                    hey man,
                    Pull a spark plug, crank the motor, and see if you smell gas. It's easier than disconnecting the rail. Just be sure you unplug the distributor, or the motor will start.
                    There is also a service port that you can use. I believe that's what C91BLX7 is referring to.
                      Yes there is a bleeder bolt at the left end of the fuel rail. Just loosen it up, careful fuel might be under pressure and spray out.
                      1992 Accord Wagon (RETIRED)
                        my endless gratitude for all the help!
                          right now,
                          the car doesnt start at all lol.
                            somewhat simple way....... remove gas cap to relieve some fuel pressure, diconnect the fuel line from the fuel rail in the right side of the car (17mm nut), place fuel line in a glass jar, turn key to on position (not start) and check the jar. If you have fuel in there, the fuel pump is working....... at least enough to prime the system initially
                              damn I was about to post that...but yeah that's a easy method to relieve some of the pressure.
