if you are getting spark, and you def. have fuel at the rail...than it can be your ignition switch. And its def. not throwing a code correct? take your ignition switch out and have a looks see. shouldnt take you no longer than 30min+ to take it out n shit...
1990 Accord Ex Questions
'Leads' = 'plug wires'.
The resistance in the leads builds up as they age, so eventually you have X current entering the lead at the distributor but only X- current arriving at the spark plug (and the leads heat up more than they should, but you won't feel the difference by touching them).
The 'ignitor' in the distributor has a limited life span, commonly failing after a fairly high mileage, you might want to get that checked (also, high lead resistance is one cause of ignitor failure, so if the ignitor is toast you may well need new leads to keep the new ignitor alive).Regards from Oz,
John.
