auto tensioner conversions
    why is this needed when doing a h22 5speed swap???????????
    auto tensioner's tend to fail more often than the manual one, but the auto is fine if you do your regular maintenance. I think most of the auto's fail do to the lack of care by the owners. Usually the guys who have upgraded valve train typically do the conversion as well. With h23 manual tensioner it is usually a tight fit to get the timing belt back on.
      manual tensioners have less chance of failing, because once you set it, it stays...its like tightening a bolt down. Whereas the auto tensioner has a spring that tensions the belt, and that spring can sometimes fail causing the T belt to slip, then causing major valve to piston contact.....that means you'll be in for a lot of money.
      But like the other guy said, if you do the H23 tensioner, the belt is a BITCH to put on. It doesn't just slide on, you have to kinda force it on.
