vacuum box and charcoal canister
    What would you have to do to remove the vacuum or emissions box and the charcoal canister and still have it run right. What is the exact purpose of each. Appreciate any help.
    ive already removed ac, ps, and auto to manual swap. Just wanting to get rid of the canister and vacuum box
    Well, from what i was told, the charcoal canister removes access gas fumes. you can just lift that out and cap off the lines, but you might have to move some things out the way though. I never tried to remove my vacuum box, since the map sensor is in there, but im sure somebody has, so ask around about that.
      You can ditch the charcoal canister no problem, just do not cap off the vent line for the gas tank, it's just underneath the feed line for the fuel filter. Regarding the vac. box, obviously save the map, but if you are not running a chipped civic/teg ecu, you need to keep all the EGR components that are in there, so basically, leave it alone!
        thanks ,that helped me alot and that was what i was wanting to know, i had seen people not using there vac box and was just wondering. Want all the room i can get..
