As a member of this community, you are expected to know and follow the rules. READ THEM HERE!
help.....
    help.....
    my fans wont turn on.... so i replaced the relay under fuse box and teh timer inside the car...
    but now i think its the switch its the one folllowint the radiaotr hose from the top the green one right????
    well i checked it if it worked with the test light...
    only one wire lights up
    are they both suppose to light up????
    IT MAY BE AUTO BUT IT SURE RUNS FAST FOR A F22A6
    Close the circuit by putting a paper clip in both sides of the plug (like checking for CELs), see if the fan turns on when start the car.
      like plugging it to the wires or the one thats connected to the motor???
      and if it doesnt turn on with the clips???
      it doesnt work?
      this is the one that i am talkinga bout..
      this one controls the fans right???
        I can't tell what plug that is in the picture. But, follow the LOWER (my bad) radiator hose to the thermostat. The fan plug is the green one next to the thermostat.
        Edit: Lower hose, not upper.
          I can't tell what plug that is in the picture. But, follow the upper radiator hose to the thermostat. The fan plug is the green one next to the thermostat.
          well the one that ends with the bg hose right its a green on connected in front of the motor????
            Sorry, I meant to say follow the lower radiator hose. You can't see the plug by just looking straight at your engine, it's a litle hidden. But, if you can find the thermostat, you can find the plug.
              well i jumped the front green one that ends with the front upper hose....
              its a green one......
              but what other one are u talking about...?????
              i jumped the one in the front and the fans go on when the car is off.....
              but they go onwhen the ac is on...
              is there a pic i can see?
                It's kind of raining here, can't go take a pic. Follow the lower radiator hose to the thermostat. Beside the thermostat, there's another green plug. That's the plug you want to jump, not the one that is circled in the picture above.
                  Pictures:
                  Look behind the distributor:
                  See the green plug?
                  [/IMG]
                  It's right here:
                    cause i jumped the one that is circled and it turns on the fans when its off...till i unplug it....
                    soo i am suppsed to jump the other green one...
                    after i jump start it what em i suppose to see.???
                    i also toook of my thermostart off do i put it back in?
                    cause i thought it was not opening and stuff..
                      (See pics above)
                      When you turn the car on, you'll see the fan on. It keeps it on, regardless of temperature.
                      The thermostat itself, or the housing?
                        (See pics above)
                        ok...soo if the fasns go on while jumped.....
                        the sensor doesnt work right??
                        i bought a new thermostat imma put in..
                        soo i just look if they turn on with jumped pins the sensor doesnt work rihgt?
                          Car has to be on (not started) for the fans to turn on. If they turn on, the fan motor is good. Could be a bad sensor.
                            ok well.....i turned on the car and the fans stay on ....
                            helps cool the coolant down alot...
                            is it safe to drive like that????
                            u think its that sensor that i jumped well the socket part??
                            what is it called?
                              what is it called?
                              I've been driving like this for over a year. Keeps everything cooler. I don't know what the plug is called.
