Stalling problem
    Stalling problem
    Hi my car was running fine i went home then went to go out in the car again and then it starts then cuts of then. I start it but then as soon as i touch the throttle it cuts then i start it goes like normal then cuts like 2 secs later i just to see if it getting fuel it is but don't seem a very strong pressure coming out do you think it fuel pump.
    It could be the fuel pump, clogged fuel filter, or the main relay. It could also be a bad ground. I had a problem with a bad ground once and the car would just shut off when I hit the throttle. I'm guessing because the voltage went up from the alternator spinning faster and made the ground lose more connection. I moved my battery to the trunk and when I did that, I replaced the grounds and never had that problem again.
    PARTING OUT MY 1990 EX COUPE!! EVERYTHING FOR SALE! CLICK HERE
    Listen or download the first 4 songs I completed for my new upcoming album here!!
    My member's ride
      check spark plugs and ignition related components. had this happen to a customer's car after i put in a new transmission and it was just coincidence that it stalls after i try and restart the car or touch the throttle.
      replaced cap, rotor, wires and plugs.
        o cherrs guys ill check all that
          i would add a ground just to see if that is it because if it is and you replace everything you will still have the same problem in the end. and everything is working for it to start in the first place more in likely if some thing has gone bad it will be the coil seeing how most of the components don't work then stop normally
            well i just noticed now that it dont take so long to stall and it well let me press throttle a little but now there like black stuff coming from my backbox but not normal place the inside of the backbox where it goes from the tube to the back box dripping down it but when i start it come out alot more i want to drive my accord
              my bro had the same prob n when replaced all that it worked fine
                fuel pump working and the spark plugs be changed and the cap and wires still car is doing same
