i bought my first car( a 93 ex coupe) and now im getting code 41 which is an o2 sensor but when i changed it and reset the memory it still keeps coming up. does any know what else i need to replace or do.
code 41
That was probably to the OP, but yes, I did. My buddy just bought a universal Bosch for his b16 hatch, and asked if I'd help him install it. I told him 65 times not to get Bosch. When he calls for help, I'll most likely lie and say I'm busy with something. It'd just be a waste of time installing.
98' Mustang 3V Swap
11' VW CC R36
My Chilton's says a 41 is an "Oxygen Heater Sensor"...is that o2 sensor
Originally posted by JarrettIs there a goal you're trying to accomplish besides looking dope as hell?
Yea that was to the OP. There is always problems with those Bosch's. If he already bought the Bosch, tell him to make sure he cuts the harness of the OEM sensor and put it on the Bosch.Originally posted by Gotz Cb7 View PostThat was probably to the OP, but yes, I did. My buddy just bought a universal Bosch for his b16 hatch, and asked if I'd help him install it. I told him 65 times not to get Bosch. When he calls for help, I'll most likely lie and say I'm busy with something. It'd just be a waste of time installing.
Yes it isOriginally posted by greencb7inkc View PostMy Chilton's says a 41 is an "Oxygen Heater Sensor"...is that o2 sensor
Im having a newb moment, but arent there 2 sensors? One up top and one down under, near the exhaust..
2 O2 sensors? There is only 1. Some are up top on the header and some are under the car on the downpipe before the catOriginally posted by greencb7inkc View PostIm having a newb moment, but arent there 2 sensors? One up top and one down under, near the exhaust..
I wonder what im thinking of then, lol...
Perhaps.
They never work with our cars. They don't use the right voltage. It can be fixed by cutting the harness off the old OEM sensor and putting it in place of the Bosch one.Originally posted by cb7younggun View Postyeah i did buy a bosch, but whats so wrong with em
Yes, but no. Depends on the engine you have. If you have the f22a1 or f22a4, then your oxygen sensor is on the header/exhaust manifold. If you have the f22a6, your oxygen sensor is located after the flex-pipe/before the cat. When my o2 sensor went bad (f22a6), mine threw #1. So I'm pretty sure the code for an a1/a4 is #2. I think the primary oxygen sensor heater, is because the o2 sensor's not heating up correctly?Originally posted by greencb7inkc View PostIm having a newb moment, but arent there 2 sensors? One up top and one down under, near the exhaust..
Meaning, it's failed/failing.
98' Mustang 3V Swap
11' VW CC R36
I have a F22A4 and my sensor is right before the catOriginally posted by Gotz Cb7 View PostYes, but no. Depends on the engine you have. If you have the f22a1 or f22a4, then your oxygen sensor is on the header/exhaust manifold. If you have the f22a6, your oxygen sensor is located after the flex-pipe/before the cat. When my o2 sensor went bad (f22a6), mine threw #1. So I'm pretty sure the code for an a1/a4 is #2. I think the primary oxygen sensor heater, is because the o2 sensor's not heating up correctly?
. I think you might have that backwards. F22A4 is before the cat and F22A1 and F22A6 is on the header
