short shift
    short shift
    i choped my shifter down and the gears still feel long what can i do to fix that ? want shorter shifting
    there is DIY for this. very easy and cheap. i did about 6 months ago. check the diy section
    ^^^^CLICK IT^^^^^
      long gears have to do with the transmission not the shifter
      no matter how short your shift is, your gears will always be the same
      峠 で ドリフト を して 下さい。
      steam linky facebook, y0 俺 は 走り屋 です。 clickable ^
        Thats not what he meant. Just get the prelude shifter like I got.
        NEW PSN
        H22wagon
        New project. 95 EG HB H22
        RIP
          Stock 92/96 Lude shifter is a great upgrade, but bottom line, you need to raise the pivot point higher up on the shift lever. Check out the DIY's to get some ideas, you can def. get something together. Shorting the shift lever does make somewhat of a diff, but it doesn't shorten the throw.
            True That The Prelude Shifter Works Like An Aftermarket Short Shift...smoother Shifting I Say!!! Just Dont Grind Your Gears By Shiftin Too Quickly...pleez
            Heart and Brain Transplant fail I had to pull the plug
            My new best FRIEND!!!
