In general steps (or specific if you feel extra helpful ) What tools would I, a home mechanic, need?
How would I go about replacing a intake manifold gasket?
p12 on sale:
http://www.cb7tuner.com/vbb/showthre...46#post2245646
Bisimoto Heat-shielding Intake Manifold Gasket and Rear Engine Motor Mount for sale:
http://www.cb7tuner.com/vbb/showthre...95#post2246795Tags: None
it's really just a 10mm and 12mm bolts/nuts you are dealing with on the intake manifold.
just disconnect all the electrical (IACV, EGR, TPS, Air temperature etc)
disconnect primary fuel rail line (14mm)
and then unbolt the intake manifold (bottom bolts are hardest to get to)
rip it off and clean the gasket via razor and/or wire wheel or brush
with the intake manifold off, id highly suggest replacing the rear motor mount, cleaning out the egr ports and valve or just upgrade the entire intake manifold.
Originally posted by wed3k View Postit's really just a 10mm and 12mm bolts/nuts you are dealing with on the intake manifold.
with the intake manifold off, id highly suggest replacing the rear motor mount, cleaning out the egr ports and valve or just upgrade the entire intake manifold.p12 on sale:
Originally posted by Granite CB7 View PostDef. listen to Wed3K, while the IM is off, you should also check and or replace your oil pressure sending unit, if it's leaking. Bare minimum, clean out the entire EGR tract if you're going to run EGR. It is possible to do everything from the top of the motor.
I want to upgrade to the Bisimoto intake Gasket.
http://cb7tuner.com/vbb/showthread.p...+intake+gasket
Hey, might upgrade to the h23a1 IM aswell. Asking junkyard through the internet...one dude asked for $489+ for the IM LOL. What should I make sure of when buying a H23A1 IM and TB if I buy it off a JY? Ebay only seems to have IM off of h22 Prelude S's
found the DIY, just wished it had pics.
http://cb7tuner.com/vbb/showthread.p...ght=h23+intake
p12 on sale:
