car sputters and bogs
    I got a 92 lx. Car is kinda hard to start. I have to give it gas to start. after it warms up it idles fine. It bogs when i give it gas like it wants to die. I can hold the idle at 3000 rpm and sounds normal. It just sputters when i try to take off. What can be causing this?
    What i've done: Cleaned Iacv, EGR, Adjusted Fitv, replaced plugs, wires, cap, rotor, and even switched a working dizzy from another car. I am lost! it still bogs.
    you havent check anything with the fuel yet though-does it do it every time or just after sitting for awhile?
      Right now, it is doin it all the the time. I can hear the fuel pump winding. Fuel filter was replaced also. Not really sure wat else to check with fuel.
        You can do a test next time you start it to see if it may need a new fuel injector or fuel pump. Cycle the ignition key from off to on (not start) 3 times, waiting 10 seconds in the off and on positions to allow the computer to time out. This should prime the gas lines and if the car then starts on the first try without touching the accelerator, you'll know the problem is fuel pump.
        it could be you injectors are dirty or a bad fuel pressure regulator-check your pressure
          holding the pedal down while cranking the engine commands the computer to attempt to crank without pulsing the injectors. This also holds the throttle plate open allowing high airflow into the engine. This allows the engine to crank and start without the first few milliseconds of fuel injectors kicking in. Enough time for a flooding condition to be cleared.
            Mine did this TWICE, and both times were a fouled plug. Was there oil in one of the plugs? In my buddies old Probe, he had this problem, and it was the fuel pump.
            98' Mustang 3V Swap
            11' VW CC R36
              sounds more like spark issue which is more common than fuel issues on the f22. check which cylinder is missfiring.. pull plug wires one by on with engine running and check for change or no change. if there is no change that is your culprit cylinder. try replacing the wire with a known good one. just because it looks good doesnt meant its good.
              member ride thread
              DIVULGE MOTORSPORTS
                This is what i have to do. hold pedal down.
                No oil in plugs.
                I got 2 sets of wires from running car. Dizzy also.
                  check your tps voltage
                  also try unplugging each fuel injector
                  member ride thread
                  DIVULGE MOTORSPORTS
                    Gonna try that tomorrow. TPS is .45 correct? Been awhile since i checked TPS.
