I have in my car now a f32a1, i locked my f22 up and now im like finna say f it. The car run of my f22 wiring harness ecu and tranny. When i first did the swap the car pulled all the way to 7 grand like 4 times and now it wont rev past 4 grand driving it or just sitting there.My vtec solenoid has never been hooked up so tell me wat do i need to do cuz im thinking bout trying the hybrid motor with the h23 anf the f23 but i need to know there is nothing i can do with the motor to run it right.i want to order bisi cam but dont know if im just wasting time and money. o by the way the guy that swapped my motor was killed in a car accident and i cant explain everything so please help.
f22a1 to A f23a1 please help me!!!
kinda need more information such as ecu codes an any other than stock modifications.
member ride thread
DIVULGE MOTORSPORTS
would it b possible to just get past the vtec and the motor run past 4 grand on its on. one more thing when im drivin it sometimes it doesnt wanna pull like it should then i hit the gas to the floor and my check engine light comes on and then it pulls like it wants to.i was tld to check injectors but i wanna run bigger ones so then i would have to change fuel pump rail and what else???
ok, this wat i am saying sorry bout my poor choice of words.
i have a 91 with a 99 f23a1 in it. my car is throwing a fuel code 43 if remember right. it wont rev past 4 grand but it did when i first put the motor n. crzy tuning says i should put a p06 on it and it should wrk fine but i have neva had vtec hooked up and it reved to 7 grand while parked and driving. i thought bigger injectors would help fuel code so now im asking for help from my fellow cb7 tuner brother around the world and net.lol
Code 43 could very well be your o2 sensor... OR something wrong with your fuel system.
You're running the F22 ECU, which could be causing problems. If I were to guess, I'd say that your fuel mix is off due to the improper ECU (and the fact that you've been revving that poor motor to 7 grand on the wrong ECU), and you very likely destroyed your o2 sensor. Go to Honda and get a new one.
Bigger injectors are not needed. That would only make the problem worse.
Good Info
WELL MY F23A1 BROTHER I TOO HAVE AN F23A1 AND I GOT VTEC POPPIN AT 45OO RPM ALL THE WAY TO 7200...GET UR VTEC WIRED UP AND YES REPLACE YOUR O2 SENSOR IM RUNNIN A CHIPPED P28 ECU BUT ITS TUNED FOR A B16 SOMEHOW ITS WORKIN!!! ALSO YOU MITE WANNA TRY A 94-95 ACOORD SE/EX SINGLECAM VTEC ECU THAT MITE RESOLVE UR TROUBLES....BUT IM PRETTY DARN SURE ITS UR ECU CAUSE UR F22 ECU IS NON VTEC AND ITS NOT PROGRAMMED FOR IT SO YEA HOPE THAT HELPED...
Heart and Brain Transplant fail I had to pull the plug
My new best FRIEND!!!
Originally posted by CATCH24 View PostWELL MY F23A1 BROTHER I TOO HAVE AN F23A1 AND I GOT VTEC POPPIN AT 45OO RPM ALL THE WAY TO 7200...GET UR VTEC WIRED UP AND YES REPLACE YOUR O2 SENSOR IM RUNNIN A CHIPPED P28 ECU BUT ITS TUNED FOR A B16 SOMEHOW ITS WORKIN!!! ALSO YOU MITE WANNA TRY A 94-95 ACOORD SE/EX SINGLECAM VTEC ECU THAT MITE RESOLVE UR TROUBLES....BUT IM PRETTY DARN SURE ITS UR ECU CAUSE UR F22 ECU IS NON VTEC AND ITS NOT PROGRAMMED FOR IT SO YEA HOPE THAT HELPED...
do what crzy tuning said and send them an ecu before you destroy your motor
smoke tires, not drugs.
You're revving a motor that's running a B16 tune to 7200?
Please, don't give any more advice in the Beginner Forums... someone is going to break their motor because of your bad advice.
And for the record, the F23A is a crap engine.
k but thats all i got for right now the f23a1. so until i can get a h22 that is wat i got but wat about the g fusion motor? and does anybody know where i can find those white honda wheels that has like 7 or 8 spokes i dont know the name butthey come in 16 and some of the accords of the month has them. deev wat motor are u runnin?
