need some exaust help
    hey guys i was woundering about my exaust
    right now my set up it very crackly and rasspy
    i have an idea to get a resonator or two welded on
    i have no idea hwere to find some small like 2.25 inch resonators??
    any help
    thanks!
    you could use a 12 inch glass pack
      What kind of exhaust? cat-back? Just a fart can?
      edit: don't mind the fart can. If you're looking for a 2.25", then you most likely have a cat-back of some sort. But what kind? Did you keep the catalytic?
      98' Mustang 3V Swap
      11' VW CC R36
        it just has a header to a "high flow cat" to stock pipeing to a stock muffler
        it just sounds raspy at like 2-4 rpms and i thought it would be good to get another small resonator welded on
        thanks
          Thats Exactly How Mine Sounds But It Doesn't Bother Me That Much.i Think That If U Weld A Resonator To It U'll B Adding Another Restriction Maybe I'm Wrong(correct Me)if I Am.
            yah tyhats what i was thinking, but i also saw a guy on here that did that, and it did help[ so i was j.w
              make sure that your "high flow cat" actually is a cat and not a test pipe. Also I would not add a glasspack. I have one in place of a resonator and it does not do anything. I would recommend a round muffler like a straight through magnaflow.
                junk yard for the stock just an idea lol
                kiss my grill
                Members Ride
                  ok so should i change out the
                  ""test pipe "
                  for an actual cat converter? that will be fine even wioth a header?
                    thanks
                    I have the 4-2-1 e*** header, high flow cat (VIBRANT), and the stock EX(EXR canadian) muffler with the dual tips. I dont hear anything. Maybe your muffler is shot?
                    90 Accord EX F22a1 Auto R.I.P.
                    2011 Mazda 3 Hatch 2.5L GS sport HELLO!
