engine work
    engine work
    ok so i want to get a few things for my f22a1 from bisimoto such as a stage 2 camshaft and cam gear
    will i have to do any other work to get these to work as well as they can of are these things i can just throw in?
    Putting in a camshaft isn't exactly like throwing on an intake.... It's a tad bit more in dephth and exact than that. You're going to need cam lube and a torque wrench, plus new spark plug tube seals and a valve cover gasket. You're going to have to also redo the timing belt since thats what drives the cam. Plus all the torque specs and sequences for the things you removed. I 110% recomend getting a helms or oem shop manual for this.
    If you feel confident in accomplishing that, then you're going to need to replace the valve springs and retainers. You have two options for install here. More special tools and and access to an air compressor to keep the valves closed while the head is on OR take the head off and have them done at a machine shop which requires more time and money due to having to buy a new headgasket and headbolts. Plus the machine work required to the head....
    In my opinion, if you're asking questions like this. You aren't ready to put the time or the money into this kind of mod. So read up some more, search around, and see where you stand. Hope that helped.
    Finally Up and Running. Numbers to Follow. Check my MR
      on a stock block you may not see the gains your hoping for mainly due to low compression. You will see gains though. highly suggest valvesprings from bisi as well but unless your pushing 8000+ rpm bisi told me stock retainers will be fine.
      member ride thread
      DIVULGE MOTORSPORTS
