seafoam...?
    seafoam...?
    what does it do and how will i benefit from doing it to my cb? someone told me i should, my car is a bit sluggish and not getting the gas mileage it used to and should be getting.. any help guys. thanks
    word. i am also interested in knowing.
    Accord SE
    93se
    Members Ride
    Bought from: H22wagon93, Theos92VR4, Hondafan81, Father Time, DarkHusk, Gunrunner, FamousFreak
    Sold to: sulimed, BurtonRiderT6, tishock
      Googled
        it cleans out all the carbon and junk in your engine. I did it to my F22 at 160K miles and it improved mileage on the hwy a bit, like 2-3 mpg. A LOT of white smoke came out.
          Originally posted by Leung View Post
          CB7Tuner'd
            thanks man. yea i could google it too but just thought ppl on here could give me a better idea of what i would be doing.. like walk me through the process. and let me know if its a recommended thing to do..
              Do it. It's worth it. I did it on my Integra awhile ago. It shot out a lot of smoke. Just make sure you follow instructions from experienced people carefully, otherwise you could flood your motor.
              Have somebody rev it up a little to like 2-3k rpms. And slowly suck in some seafoam from a vacuum hose. Don't drown the hose in the stuff, just put the hose near the seafoam and it will suck it in. I poured the seafoam out into a small bowl to make it easier and just refilled the bowl every little bit. EDIT- Oh, it's normal for the motor to down-rev when it sucks the stuff in, that's why you want to rev it up a little.
                i might try this on my cb before the VA meet on sunday.see if it help my mpg.sound like its a good thing to do to help clean out the engine.
                  Brace yourself for the smoke.
                  1996 Honda Civic LX 2009-2012
                  2012 Kia Optima LX 2012-2013
                    That's the best part!
                      I heard mixed reviews when I was learning about it but it worked pretty well for me
                      Underground.Society
                      Originally posted by Deevergote
                      If it doesn't really matter... shut the fuck up and let it be.
                        Better than cocaine.
                          i didnt quite understand hows its done
                          can some1 explain it in a little more detail please
                          tnx
                            tnx
                            You take off a vacuum hose and use the hose to suck in the Seafoam. You also put a little bit in your gas tank to clean your fuel system and a little in your crankcase. When I used Seafoam, I took a empty 20 ounce soda bottle and put some Seafoam in that. Then I took a funnel and connected a vacuum hose to the bottom, poked a hole in the 20 ounce bottle with the Seafoam in it and placed that inside the funnel so the Seafoam dripped out one drop at a time. It worked pretty good but you don't have to do it like that. Just use the vacuum line to suck up the liquid.
                            PARTING OUT MY 1990 EX COUPE!! EVERYTHING FOR SALE! CLICK HERE
                            Listen or download the first 4 songs I completed for my new upcoming album here!!
                            My member's ride
                              i like it
                              so i finally get my car started after a 3 day ordeal, and i decided to seafoam the shit. initially the car sat all winter and the oil turned to sludge and the car wouldnt crank from lack of oil pressure. so i drain all the oil out and it was like molasses. then dumped in motor flush break up the sludge and it all finally all drained out after sitting overnight. the i put in fresh mobil one oil and fresh oil filter. it still wouldnt crank so i decided to burp it by unscrewing the oil filter and cranking the motor. the oil started coming out and then i retighened it. then after i figuered i crossed the ignition wires it started. i was like that you god! i let it run for fifteen minutes and then went to the store and put in seafoam in the oil, gas, and intake. it smoked like a bitch. it looked like i had a smoke machine in my trunk. it ran much smoother after the smoke stopped.
                              overall i must say im impressed.
                              goodluck xfactor
