where do you disconnect the cable from the cruise control unit to remove it?? doesnt work anyway figured i might as well make some extra room
cruise control question
If you're talking about the servo, just follow the throttle cable that goes to the LF corner under the hood. The servo is a circular-shaped container. It is right behind the left headlamp assembly.
"The fault-finder will find faults even in paradise. Love your life, poor as it is. You may perhaps have some pleasant, thrilling, glorious hours, even in a poorhouse."-Henry David Thoreau
There's a line running from the firewall, near the steering wheel, forward to the disc/bulb thingie which is the cruise control servo. I suppose it contains two cables connected to the accelerator and the speedometer.
But if you follow the actual throttle cable past the throttle body, it continues across the engine bay and down to what looks like a motor/actuator in the LF corner. What is that?
I guess this is more of a "not-cruise-control question." Anyway I'm wondering because my cruise just broke, and then I noticed the cable going to this mystery part had escaped its retainers and gone slack. Snapping it back in did not help
Guess I need to replace the servo?
