alright this is weird i have a leak near my radiator and its leaking either motor oil or tranny fluid its like a redish brownish color. i think the hose connects to the radiator help and i am losing my coolant as well
leak near radiator
if it's an automatic you should have tranny lines running to your radiator. they may be loose or the housing where the line goes into the radiator might be cracked. You said your losing coolant also... so it has another leak too. probably have some cracks in your radiator. do you have some pix? that would help alot.
It is very common for a rad to leak at the lower seam on a honda. Especially If you had a bump in the front end, i.e. (even a light contact with a parking median). The slightest bend or twist in the core support can destroy a rad.
The tranny cooling tube that runs through the botton of the rad may also be affected.
Is there any oil residue in the coolant itself? If not then it is more likely that you have two separate leaks.
