cranking problem
    cranking problem
    My car cranks when it wants to. i just fixed a blown head gasket but is it possiblemto have a messed up distributor? it cranks up jus fine i the mawning but then in the mid day i may have to give it a lil gas so help
    Well your car is electronically fuel injected so no matter how many times you hit the gas pedal its still going to get the same amount of fuel when cranking. I did a headjob for a customer about 2 weeks ago on a 97 accord. We held the car for about a week till she paid for it.... and every morning pull ing it out of the shop it would fire right up but in the afternoon going to pull it in it took about 5 seconds of cranking.... and it had a little smoke. so we let it run for about 45 minutes and as far as i know it starts up fine everytime now... The customer was happy and i was happy!
      yea it smokes when it cranks. it does crank in the mawning but in the evening and when i drive it for bout 20 mins thats to and from school then iget out of it and try to crank it and it just spins over and pisses me off!!! so then i let it sit for bout a hour go back out and it starts but i still see the smoke in my rear view and its just there. my mechanis says it steam but it didt do that before my head job. so what the deuce
        did u make sure everything was TDC? are you throwing any codes, u sure u got all the groudns connected EVEN THE ECU GROUND UNDER THE THERMOSTAT HOUSING?
        Retro!
        Hater
          i am throwing a fuel code 43 but that but happening. i havent checked that but i will in the mawning. would you think it could be anything else could check?
            43 is also called the "rich" code. Be sure you have enough spark to combust.
            1996 Honda Civic LX 2009-2012
            2012 Kia Optima LX 2012-2013
              if your getting code 43, confirm that the fuel pump is turning on.
              since the car is running then it can be a fuel delivery problem.
              Retro!
              Hater
                fuel pump is turning on but the rich thing bugs me
                  how do i check the spark combustion??
                    i changed my rotor button and dizzy and problem still occurs.wat the deuce could it b? i did fine until it warmed up then kept sputtering
