¿electrical Problem?
    so heres the thing,the gauges(rpm,speedometer,fuel gauge and temperture) on my 92 accord arent working ,i thinkk it mite b a speed sensor or sumthin,the clock on the inside doesnt work/turnon,the turn signals dont work but wen i press the emergency lights button they work...so0 idk wats up wit that,so if anyone knows what could be wrong with my accord plz tell me
    Sounds like a blown fuse. Check the stereo fuse in the drivers side kick panel
      yea i chekked that months ago,all fuses r good all relays r good,n just the other day i gutted the interior just the dash is left n the driveers seat,no radio/stereo
        i just did that thing with th paper clip and the blue connector,the ecu only blinked once,is this a code 1 O2A - Oxygen sensor #1? Code1 Heated oxygen sensor A? or is it just nothing ?idk if this is impportant but last year i changed the ex from a auto to a 5 speed,i used a the trans off a exr and i believe i also changed the ecu,got nw headersand changed the spot where the oxygen sensor where from the headers to the pipe Under the center rear of engine,idk if this did sumthin it shoulnt have
