Plz Help!!!!
    Plz Help!!!!
    hey guys, i really need some help, i have had a little problem with my car over the past month, whenever i go to start it, it would fire up then stall then when i go to start it up again it would not fire up, it would just turn over. eventually it starts after 15mins, but it only happens sometimes.
    Today however i think it has completely fucked up, now when i go to start it and turn the ignition on it makes a weird grinding sound from inside the dash. then when i fire it up the engine light is on and it is idleing very rough also when i give a rev it just seems to splutter. When i start driving if the revs go over 3500rpm it just splutters, cuts out and doesnt go anywhere also there is no power it is really struggling, it also stalls whenever i stop at the lights.
    i am not sure what is going on but i am really fed up! has anyone else had this problem? can someone please help!
    Thanks
    Just to let you know, you should really read the stickies. You will more likely get responses to your question if you write a better title then "Plz Help"
    Now for the question. Do you have a CEL? Can you take a video/audio recording so we can hear the noise you are talking about?
    PARTING OUT MY 1990 EX COUPE!! EVERYTHING FOR SALE! CLICK HERE
    Listen or download the first 4 songs I completed for my new upcoming album here!!
    My member's ride
      He says the engine light is on. CEL.
      Look up the sticky that shows how to pull and read the CEL codes, and that will tell you what your problem is.
        Ahh ok I missed that part for some reason. Probably because that was 3am when I just got home from a long night of partying .
        But yea to the OP, pull the codes and that will give us a starting point to help you with your problem. It sounds like a timing issue to me though. Let us know the codes when you can.
        My member's ride
