I was looking at the white project build, that seems like alot of money spent. Are high flow injectors and a higher volume oil pump nessesary for running 12-12.5:1 compression. That is what I was thinking of building roughly the same compression, but with only stg 2 cam, and I cant afford that beautiful header though I wish I could. Would it probably be better for me to go with 10.5:1 and mill the head a little, seeing as how this is my first engine build (on a honda and for performance) I have rebuilt toyota motors before, but never upped their performance. Any suggestions on if extra Oil press, fuel inj, are totally nessesary.
Another compression question
1989 cressida: Polycog diesel ultracharged, high tension muffler bearings, Manestically spaced pivot bearings, High definition halogen fluid, Flourescently scored bio-fuel seperator, flux capacitor and a Sega Genesis hooked up to a 9" b/w tv via cable to antenna converter.Tags: None
Even if I go with 10.5:1 injectors should still be done? Do you know what size would be good to use? Does anyone know about if an upgraded oil pump is nessesary, or can I shim the pressure release spring (on toyota there is a big spring with a check ball that determines max pressure depending on spring strength) to make it run higher pressure.1989 cressida: Polycog diesel ultracharged, high tension muffler bearings, Manestically spaced pivot bearings, High definition halogen fluid, Flourescently scored bio-fuel seperator, flux capacitor and a Sega Genesis hooked up to a 9" b/w tv via cable to antenna converter.
You have stock F22 injectors? I would upgrade them if you plan on pushing over 180whp or revving over 7k. They'll be close to maxed out at that point.
On the high volume oil pump, you don't need to buy a new one. You can rebuild your stock one for cheap and mod it yourself. Do some reading on modifying oil pumps for more flow. Or you could send it to us and we can do it for a price as well.
Deev, why do you say that if Cisco did it in his build, everyone should do it(that is pretty much what you're implying)? His build isn't done and nothing impressive has come from his build, yet. Why would you follow something that isn't proven? I mean, I have less compression, stock cams and much more power than he put out. It's not fully tuned yet, I know, but still.
Also, his build isn't all that extreme either. In today's engine building world, his build is considered a very mild NA build. 12.5:1 isn't much.
I found a speed part shop near me, and talked to one of the guys there. He seems to think that 12:1 is a bit high, told me that 10.5 should be good enough. Something about needing a bigger cam to bleed off some cylinder pressure with 12:1 or higher. But I dont know.. Still learning and planning. One good thing is that he can help me round up some of the parts I cant find on bisimoto.1989 cressida: Polycog diesel ultracharged, high tension muffler bearings, Manestically spaced pivot bearings, High definition halogen fluid, Flourescently scored bio-fuel seperator, flux capacitor and a Sega Genesis hooked up to a 9" b/w tv via cable to antenna converter.
