As a member of this community, you are expected to know and follow the rules. READ THEM HERE!
whats the difference?
    what does obd1 and obd2 mean? and how does it work?
    in a nutshell, OBDII uses more sensors to manage engine performance and emissions. On hondas that mostly means the addition of knock, crank, secondary O2, and a few other sensors. They are typically easier to diagnose because they have a more sophisticated fault check system and you can stream engine data through a scan tool.
    The flip side is that OBDII is more difficult to work with when modifying the engine because the expected sensor values are more rigid. (Plus, if you need to chip your ECU for custom programming, I don't believe OBDII ecus are very capable of this.)
    A lot of people choose to convert to OBDI to get rid of 'unnecessary' sensors and for ease of 'chipping.' Although with newer platforms such as the K-series motors, there is no alternative to OBDII and therefore you must typically pay out the ass to have a modifiable/programmable OBDII ecu.
      its easier to pass emissions with a obd1 car I know LOL
        can someone give an explaination as to how would the redtop H22a be converted to the OBDI
        '91 Concord Metallic Blue. Status: under construction
